BMW Rims
Afroclipse
898
Dec 22, 2006
Houston, Texas
Is there a way to make BMW rims fit on my DSM the lugs are to big for my DSM 19x8
If the Lug pattern, offset, and wheel size fit into wheel well then it might. First off do BMWs use a 5 x 114.3 bolt pattern? A quick search tells you BMWs come in 5 x 120 bolt pattern, so probably not.
You could buy/make an adapter plate between lug nuts, but for a wheel that size the offet is probably not going to work with an adapter.
No they won't. And yes you could make a spacer for them, but that's just a waste of money and time. Do it right, and research your car, and figure out what set of rims you really want, rather than slapping another car's rims on them.
