BM tranny lsd
95Eclipsers
346
Nov 4, 2002
Fairfield, Maine
There only $199 on slowboyracing.com how good do they work, and are they reliable and wont explode on launch!?????
If you even have to ask, why would you use it?
As soon as I see a true DSM shop use one over a true LSD I will invest, maybe.
I have that thing and it works pretty good. I havent broken it but I run street tires and it just lays posi strips now. However i have no torque steer
well it must help with traction then, i wonder how much it would handle on slicks, also how hard was it to install?
The install itself was simple. Removing the axles, supporting the engine, dropping/disassembling the tranny tends to be alot of work though. I've heard stories about how many people have had luck with the insert, I am not one of them. :(
Hey if your stuck with FWD It seems like a traction option to me if it works and doesn't break. I don't know how much it would improve traction at launch. Any comments?
i have the phantom grip locker in my fwd. on launch it helps alot, almost no wheel hop and i can launch my fwd at like 3500 and hardly spins with 225s mastercraft zhp tires. on a burn out which i never do intentionly but when i was testing how hard i could launch the car i tried at 4500 i left two marks side by side.
I talked to Mike Huml from a "true DSM shop", and he says he actually prefers the BM Tranny lsd to the Quaiffe. He is making 400 whp, I think that speaks enough for the product, well enough for me to have bought it anyways (don't have it installed yet though).
  • Wanted 6 bolt NT water pipe
    • chrisman287
