Big 2.4 mistake
crazy_skier
246
Jan 26, 2006
Alexandria, Minnesota
Hi, well I screwed up on my 2.4 and used the 4G63 cam gears and a 2.0 belt, so how quickly do I need to remove it and change it out ( I have had no knock, but the exhaust cam is retarded a half tooth if retarding is counterclockwise) so should I park it and wait for the 2.4 gears and belt or would it be ok to keep on driving like this? Thanks alot :sosad:
If I remember correctly the timing is different by a half tooth, but I personally would park it and wait for the 64 gears. Is it worth ruining valves, head, or pistons? Not to me. i know there are threads about using 4g63 gears on a 4g64. The search button is your friend. Good Luck
I'm parking it until I get my adjustable gears and the gatorback belt, I did use the search but couldn't find a definate answer on my question... it was all contradictory so thank you all
