best of 2g and 1g short blocks??
97spydagst
268
May 14, 2004
Burley, Idaho
ok i think i got crankwalk. I have a 1g block that i em gonna be putting in. So i was wondering is there anything i can use off my 2g block i heard pistons is that true?? Is there anything else i can use. Plz point me in the right direction thanks :dsm:
Unless you got a 1995 then don't use your pistons.
For the 6bolt block use...
1g big rods (90-91 I think)
2g pistons (95 only)
Should be a good setup for you internally on the bottom end.
Which head will be up to you. I was told to use my 1g head that I'm buying with the 1g block I got. So I went with a 1g head. I was going to use a 2g head because I was trying to save money but me basically being told it would save all of like 100 bucks for me I just went 1g ported.
What type of performance are you wanting out of the car?
why only use 95 pistions? whats wrong with 96 pistons? i know 2nd gen pistons raise compression to about 9-1 so what do 96 pistons do then?
95 pistons are the strongest pistons you can get from a 2nd gen other than buying forged pistons.
Fill out your profile including year/cars detailed information
