Best injectors for big power on E85?
are you trying to say that you can build 30psi boost faster than your fuel system can? How far off target do you actually see your fp? You realize that the injector flow is a sqrt function of the pressure right? Even if your fuel pressure was 50% off target your afr's would only dip 23%. It would take quite a bit of full power running to cause a meltdown on a conservative E85 tune.
Do you have links to studying the fuel system as a damped oscillator?
