Ball Joint and Tie Rod Replacement Boots
Enilator
46
May 11, 2003
Topeka, Kansas
I had to take my front end apart the other night to get new bearings put in the hubs. In the process the ball joint boots were damaged and the tie rod boots were shot. Of course there is noone around here that can get replacements and i dont want to spend 120 bucks for new ball joints and tie rod ends just to get boots. Has anyone else ran into this problem?
is it the tie rod boot that broke? You might be able to get away with just the bushings, but depending on the mileage replacing the whole tie rod end might not be a bad idea. Keep in mind you will more than likely need and alignment after such a job
price of a tie rod from a local parts store most likely will be the price of haveing new boots shipped, just get them at your next alignment
Just did the tie rod ends on my Talon, and they were just $13 each, and easy to replace.
  • Wanted 6 bolt NT water pipe
    • chrisman287
