Baer Track brake pad replacement
blackGSX2g
DSM Wiseman
3,334
88
Apr 30, 2004
Kalamazoo, Michigan
Well my Baer Track big brake kit needed a pad replacement, so I ran down to the local auto parts store and bought a run of the mill $50 set of pads for a Mustang Cobra. Everything fit fine, but now my brakes absolutely suck. The factory brakes on my DD feel WAY better. I can't even lock up the tires/engage the abs at any reasonable speed. I would think almost any brake pad would be able to lock the tires on a full stop.
Any ideas?
I swapped in the whole cylinder/vacuum unit from my other AWD, lines are all bled and bled again, then installed SS brake lines on all 4 corners and bled them again. Still the same weak feel.
The old pads were awesome, even when they were way worn down. This just happened right after I swapped in the new ones so I doubt anything else could have gone wrong in the 30 minutes I took to put them on and bed them.
Did you bed the new pads?
Yep, thats where I first noticed the problem. I was hoping they would get better after a few heat cycles, but no dice.
I guess that's what I get for spending money on a good brake set-up and cheaping out on pads, I just don't understand why so many crap cars with crap brakes on crap pads can still outperform these.
I'll probably just pick up a set of good pads that some of the Corvette/Cobra guys recommend.
