Baer Front Brake Upgrade ?
Baer is one of the most respected brake upgrades for our cars. Do some looking around and I'm sure you will see that it is a great kit and used by quite a few people.
I have them and I love them. I also have the powerslot big brakes on the rear. It's a great setup I think. Check www.hopupracing.com, they seem to have great prices, that's where I got mine from.
hi, thanks a lot for fast answers.
Does anyone of you have some pics how the bear brake looks on
a 18" wheel?
I could not find one...
Thansl
Mike
a 18" wheel?
Thansl
Mike
Look at my vehicle profile. I have one pic. 13" Baer track with 18" Enkei MM2
I have Baer Pro kit Alcons 4 pistons with 13", I'll say its rocks, really, never fade, so much clamping force (19% more then stocK) + the results of having bigger rotors + good big wide pads (almost double superf. of stock) = awesome. But one thing = SQUEEEEEEEEEEEEEEEEEKKKKKKKKKKKKKKKKKKKKKKKKKKK more then a bus, maybe more like a train, sometime people put their hands on their ears (no joke) and no noise at all ??-- But the PBR 2 pistons should not do that... great upgrade even whith the noise, I'll try BG stop squeak next summer.
I doubt the calipers have much to do with the squeek... what other pad options do you have?
I've tried street pads, street/tracks pads... It's not the calipers who squeaks, but maybe because of the calipers, we have a differents kind of pads (biggers) it do the squeak. I never heard somebody with the PBR 2 pistons doing noise like a train. But speaking of train those Baer pro kit could stop a train... tough.
Give me your pad plate number or its profile and I'll fix you up with some Poly Q pads that won't do that. Save these for light track use or whatever you like. With the pad number I can probably offer you over half dozen compounds. The Wilwood pad line extends well past their own brand calipers.
Talnz167 said:
I am looking to get that exact kit soon. Easy install?
Yes, it's easy to install. Everything is bolt on. All that's to it is bolting a bracket to the spindle and bleeding the system. Everything else is like a regular rotor change. Just make sure that you use a line wrench to get those old lines off if you are putting stainless on. I screwed one up and had to use vice grips. They worked well.
Where did you get the 4-piston setup from?
price?
I have great luck with PF Z-rated for my Baer's. No squeak, great stopping power on the street and confidence into triple digits. I switch to 01 for the track which I highly recommend to anyone. I have converted all of my Hawk buddies to PF for track use on a variety of platforms: Vette, Mustang, etc. I use PF exclusively on my car(except on the rear, I use the porterfields.)
PF 01 for track or Z
