Baer brake question..
twenty5psi
815
Nov 7, 2002
Williamsport, Pennsylvania
Will the stock brake master cylinder be able to handle the baer track kit?..I had someone ask me this and it made me think about it so I figured I would ask the guys who would know..Thanks..
if I'm not mistaking, I think the Baer Track kit includes a master cylinder...
If it's not included, then it's because it's not necessary to change it.
From Baer website :
"Our Systems are not just a kit; they include everything you will need. If your application requires a master cylinder, hose, or special fitting it’s included. Systems requiring hubs not only arrive with the races and studs installed, but are also assembled with Timken™ bearings and packed with Redline® Synthetic grease."
Thank you for your reply..I thought the same thing after i thought about it since they had'nt mentioned anything in their instructions..Thanks
chris
I have Baer 4 pistons (pro touring) and my stock master cyl. You will not have any problem with the Baer track.
