Bad temp sensor or not?
ShawnsGarage
354
Jul 19, 2008
kannapolis, North Carolina
If my temp sensor goes bad will it throw a CEL? The temp gauge read fine and the fans cut on. My n/t car is spitting sputtering and jerking but does just fine in WOT. Im running NGK 6 gapped at .30. Wires are fully plugged into coil. I AM NOT getting a CEL but the car does smell a little rich. Any suggestions?
BTW im running a n/t motor, n/t injectors, n/t ecu, turbo MAF, And turbo Wiring harness.:confused:
When my temp. sensor went bad it did not turn on the check engine light. But it will make your car run rough, rich, sputter, and cut out. What it does is, it leaves the ecu in open loop, which means it's working in cold operation mode and it just dumps alot of fuel.
my fan still turned on when my coolant temp sensor went out and it threw my cel on. had cold and warm starting issues to boot. fan sensor is separate from CTS. CTS is used by computer. temp gauge sensor is the smaller one beside the CTS...on a 1G at least.
i think it has something to do with you running a turbo maf just like what jrohner said.
