bad iac or not?
Yeah mine just recently had the same problem. The black topped one is the only one that fixed my bad idle problem. The tan topped ones apparently like to die all the time.at least it's easy to change. And yeah getting nothing from 5&6 means it toast.
Nothing often means 0 or close to zero which in resistance measurements would be a short. Opens are whatever the meter displays when the probes aren't touching or infinite resistance.
A short between the pins of the ISC will damage your ECU. An open won't hurt it. In either case the ISC is bad.
