Bad Boost gauge??
smoked28
101
4
Jul 14, 2012
Keystone Heights, Florida
Ok I will start by giving a brief description of my build. I have a 2g with a 6bolt block/7bolt head, 14b with 16g compressor wheel, 550cc injectors, fmic, cyclone intake manifold, and mild 272 cams. The previous owner did all of the work. Now for the issues. When I bought the car the guy told me it had low compression in 2 cylinders, it ran like crap(wouldn't idle unless revved for minutes, and even then it would stall some times and randomly raise to 1500-2000 and hold untill reved then it would come down and gradually raise back). I fixed most of the issues (starter, clutch, master, slave, timing belt, plugged vacuum leaks, etc.) After fixing the vacuum leaks it idles a lot better(now it only takes a minute to get it to hold an idle and it doesn't raise to 1500-2000 as often. Also, the boost was set at like 25 psi so it was hitting fuel cut off, so I turned the boost down to like 13-14 psi but now(it had done this before too) it seems that the boost gauge is acting funny. When driving, I begin to accelerate and the gauge stays at about 10 psi vacuum and then shoots up to 12 psi boost and then back down when I shift. I imagined it would be more gradual than this but it is my first boosted vehicle so perhaps this is normal. That's why I wanted you guy's input. So my two questions were 1) Why does my idle randomly raise to 1500-2000 rpms and stay there until I rev and then goes down and gradually raises back up? I seem to have taken care of all the vacuum leaks so I am stumped. And 2) Why could my boost gauge be acting so funny or is this just normal? I have a video of the car boosting that I will post later. Thanks in advance and sorry for writing so much!
I am not entirely sure why your idle is out of whack but the first place I'd check and read up on is the ISC (Idle Speed Controller). This is assuming your stock ECU is still managing the ISC and you don't have an aftermarket Engine Management unit installed. You wouldn't be the first one with an ISC issue.
As for the boost issue, what you're experiencing is not normal. The opposite should happen when shifting. When my engine is under any load, whether it be 12inHg or 15psi, when that throttle plate closes and I shift the pressure drops almost to or right at idle pressure (14.5ish inHg). When I complete the shift the pressure resumes immediately to, or close to the pressure it was at prior to shifting. I would check your BoV to make sure it is functioning correctly, and not stuck closed. Also make sure that the vacuum line is hooked up on the correct nipple. Speaking of my own BoV (Greddy Type S), the top nipple is supposed to be hooked up to the vac line to give it a little help under low boost or vacuum conditions to relieve intake pressure, and the bottom nipple is supposed to remain open to the atmosphere. Hope this helps, let us know how it goes. Oh, and make sure the boost gauge is hooked up properly, and in the correct location:)
I have a greddy type s bov. And yeah it's weird most of the time it will idle from 900-1100 wich I'm assuming is normal ranges, but then I'll pop it into neutral at a street light or something and the idle will be up at 2k....and also I don't know if this is related but when shifting sometimes the throttle sticks and is kept at like 3.5k so when I catch the next gear it jumps. I'll see if I can catch some of it on video. Oh and yes I believe the stock ecu is managing everything because it came with an safc2 that is not installed yet.
And yes the line is on the top nipple of the bov bottom is open. Any ideas??
