AWD to FWD for dyno
I saw on slowboys website under the driveline category, a product that said "lock it into 2wd for that dyno run" maybe you should look at that?
Or if you were really lucky, your car could have come with JDM driveline goodies that all you have to do is undo a bolt and pow, fwd.
Interesting...
Is there any tech Info about how to install it?
I know AMS does this all the time at a charge of like $50 ontop of tuning b/c they don't/didn't have an AWD dyno.
We used to do it when we had a 2wheel dyno only, its pretty simple.
1. Drain fluid
2. remove X-Fer case
3. remove endcap of trans while in car
4. replace stock viscous with welded or eliminator
5. seal and replace endcap/ replace fluid
6. have fun on the dyno.
  • Wanted 6 bolt NT water pipe
    • chrisman287
