AWD Suspension on FWD car, is it doable?
abudobi
63
Jun 3, 2002
Owings Mills, Maryland
One of the mounts that holds the torsion bar for my lovely fwd suspension ripped in half from running around a track. I would like to get into autocross but i don't want to have this thing break again.
Is it possible to put only the independent suspension from an AWD on a FWD without doing a full FWD-AWD swap? What would you need to replace?
Is it possible with lots of fabrication... sure. Is it anything like the same swap would be in a 2G.. no.
But.. since you will not need the pumpkin it might be. No one has ever completed a 1G AWD swap, but since you won't be using all the parts...
Take a look at a 1G AWD model and see if your frame matches in any way first.
    • george bromwell
    • pma1123
    • Sdcryan1
