awd as fwd question
1Gina2G
810
May 6, 2011
Beaufort, South Carolina
, Since the center differential in my awd transmission is welded from the rebuild, that means I don't need a viscous coupling eliminator to run my AWD trans. as a fwd? So the transfer case stays on the transmission with out the driveshaft?
Is it alright to use this setup to daiy drive on, until I finish the work on my driveshaft?
Does the rear diff. Stay?
EDIT: I did not mean to post this as RESOLVED and with the thumbs up thing LOL my phone messed up earlier.
I meant to say, could it stay on the trans after you remove the driveshaft, or keep the tcase off the transmission?
No. T-case has gear oil in it. With a removed driveshaft you would lose all gear oil out of where the yoke of you driveshaft goes and toast your t-case. Thats something you dont want!
So you leave the transfer case off if you do this. Is it okay to drive around town like this? Or is it meant for the track only?
  • Wanted 6 bolt NT water pipe
    • chrisman287
