DSM Jeff
- 558
- 7
- Jun 23, 2003
Connecticut
Just looking to see if anyone is running a RMDSM front sway bar on their 1g awd. If so how did you go about getting the front bushings mounted to the subframe?
I don't run that specific sway bar, but I do have polyruithane swaybar bushings. They were deffinatly a tight fit. I used a little bit longer bolt to squeez the bushings to the subframe and line up the bolt holes. Then used the the shorter bolt to hold it in place.
Isnt it counter productive to run a thicker aftermarket FRONT sway bar on our nose heavy under steer happy cars? As far as I recall you want only a aftermarket rear sway bar. I have the Suspension technique rear swaybar myself, which is a great improvement to handling and made the car much more neutral.
