Alternator and Powersteering pump/ Picture?
madmader
124
Apr 28, 2005
Grants Pass, Oregon
have a 90 eclipse turbo
ok, i just did the timing belt and exhaust manifold work and I am putting back the power steering pump and alternator and water pump pulleys ect. I might have mixed a few bolts up on the pump/brackets or maybe not. If i could get a pic of them or describe the # and size of the bolt and possable washer/washers on it (or screw type). I have 3 bigger bolts with 2 or 3 washers on each with i think #7 on it. Where do they go? And where do the screw type bolts go.
Can i also see a pic or digram of the belts and pulleys the way they are aligned.
This might help. If not.... nevermind, it will help! Also if you need a picture of how it looks under the hood assembled, check the gallery here for engine bay photos or check out plymouthlaser.com (lots of good pictures/info there too)
:cool:
  • Wanted 6 bolt NT water pipe
    • chrisman287
