Alarm help
EasyE
Apr 30, 2004
Belmont, Massachusetts
Does anyone remember how to reprogram a new remote for the factory alarm? i remember seeing it somewhere but i have tried searching and finding it again but no luck. I know it has something to do with opening the door sticking the key in and pushing the buttons not sure of the actuall combo of keys can someone please help. :talon:
To reprogram your keyless entry system for a new key fob:
1) Turn ignition to OFF.
2) Ground pin 1 of the Data Link Connector (black 16-pin connector under
dash driver's side). Pin 4 of this connector is a ground, so placing a
jumper wire between pins 1 & 4 will accomplish this. Grounding pin 1
tells the system you are getting ready to reprogram it.
3) Close all the doors.
4) Turn the key to ACC, then back to OFF. The power locks will
lock/unlock. The system is now ready to be programmed.
5) Press a button on your key fob 3 times.
6) The doors will lock/unlock to signal that the codes were received.
7) If you have two key fobs, press a button on the second fob within 1
minute of pressing a button on the first one 3 times. Both must be programmed at
the same time.
8) The doors will lock/unlock to signal that the codes were received.
9) Remove the connection between pins 1 & 4.
Thanks alot! I think a mod should move this to the interior exterior tech forum..... :thumb:
  • Wanted 6 bolt NT water pipe
    • chrisman287
