alarm help
944g63talon
Mar 21, 2004
Scranton, Pennsylvania
OK i'm hoping someone can help me out here. I have a 94 tsi that I just put an alarm in. I tested everything before i connected wires, but my 4 ways wont work, my turn signal indicators wont either but my turn signals work, and my fuel, temp and oil pressure gauges are all screwed up. Any ideas what I did wrong?
When I put my alarm in, I hooked a relay up to the ground of the parking light switch, so basically when the +12V is there to power lights, its actually just flipping the lights to ground. I did it this way because I was messing with the signal box under the center console and coulnd't get it to work right through there.
Well I tried disconnecting the alarm out put for the parking lights and that didn't fix it so unless someone has any other advice I'll have to try disconnecting the alarm 1 wire at a time till i find the problem.
never mind guys i guess i had a brain fart when i was putting everything back together. I unplugged the black plug above the fuse box when i was installing it but never plugged it back in. Any idea how stupid I feel?
