AFC base correction: two guides suggest different numbers. Which is it?
Rice Over Wheat
1,959
5
Jan 24, 2004
Winter Park, Florida
Ironically, both guides I'm using suggest different base correction values, and are written by the same guy.
In this guide: http://www.dsmtuners.com/forums/showthread.php?t=103469
...I used the Excel worksheet and put in my data: 650's, stock FPR (43psi), and base correction = -30.77%
But in this guide: http://www.dsmtuners.com/forums/showthread.php?t=58403
...he suggests starting at -18% for 660's as a starting point.
Since 450/650 -1 = -30.8, that should be my base correction after swapping in my 650s in order to flow the same as stock 450's on the stock 43 lbs fuel pressure. I just completed my fmic install and am ready to toss in the 650s, but I won't be tuning for a few weeks. I just want to be ready to tune on a dyno but drive safely in the meantime. So -30.8 is safe right? Or should I run rich at -18%?
Thanks in advance...I'm confused here.
-18% was a suggestion for a safe starting point, -30% is the actual correction factor. I'd start somewhere between -25% and -28%.
Great, I'll set -28% across all rpm points for now, LO and HI. Thanks for the fast response!
  • For sale 4G63 Stainless T3 header w/38mm wastegate flange
    Same header you can get for $230 on eBay. Like new, only ran for 10min or so. Price is shipped...
    • GRNDSM
    • dsmmario
    • Detail
    • dsmmario
