AC Leak around radiator!
sapharage41653
Feb 23, 2005
Prestonsburg, Kentucky
Hello! I fill my AC up with R134A, will work for awhile, leaks out. Spotted the leak and it appears to be coming from around my radiator. My question is are there just lines running around the radiator or is their other things that could be leaking in that general area as well? In other words, whats the most likely culprit? Thanks alot!
A/C condensor on these are known to be rotted out and leaking
Is the condensor located on the drivers side bottom of radiator or in that area?
The condensor is the entire thing that looks kinda like the radiator but it is in front of the radiator. Usually the condensor is black. Also, has a ton of little fins like a home air conditioner.
