Abs Or Not?
The abs system looks like a small motor with a bunch of metal lines running to it, which some of them run from your brake master cylinder. I dont know were they placed them on a 1g but on a 2g it doesnt interfere with the uicp bc its on the drivers side behind the headlight. If you dont see it just follow your brake lines, they will either run to a spliter or the abs box.
Here's a picture of a stock 1g engine. The ABS module is to the left of the upper intercooler pipe, nestled in the bend and in front of the battery. You can see it has about 4 hard lines coming from the top of it. I don't believe non-ABS cars have this module.
