a quick look at log
spoolin91TSI
May 24, 2006
Aston, Pennsylvania
what do u guys think of this log its one of my 1st to date ill will be posting another once i figure out a better way and get just a 3rd gear pull:cool: 14b,fmic, 8psi(sold my boost controler BCS dosnt work), stock fuel,
This would be better in the tuning section, but I guess you can't post there yet. You have a tiny bit of knock that you can see after you shifted and then again at a little over 6k rpm's. Either way it would be a lot easier to help you if it was a 3rd gear pull and maybe a graph with some data (numbers). I also think that if I was you a boost controller would be a must right now, it can take plenty more than 8 psi. Other than that it looks good, but then again this is only 8psi.
