95 talon with eclipse rear bumper help
tylor2015
49
Feb 8, 2016
Blacksburg, Virginia
I have a 95 talon that the previous owner put gst bumpers an eclipse tail lights. Problem is the rear bumper hangs in the middle so theirs a gab in between the center lens of the tail lights an the bumper. Is there way fix that or is the talon missing somthing that the Eclipse has
Clay where the bracket supposed to be at idk if the previous owner installed the bracket back or not. I haven't remove the number yet but I do see that the bumper has 2 or 3 clips on it where it needs to be bolted to somthing
this picture shows where the bracket was and where it should be
Mine was already like this when I got it. So gotta go with what I got just trying to fix it so it not sagging down in the middle
Oh no I was not speaking on your situation, I truly understand. I have seen the Talons butchered over the years for this reason.
I did the eclipse bumper to my talon, and I had the issue because I was lazy. Quick fix is to take a ziptie from the bumper to the middle taillight holes and tighten it up. or you can do it properly and have a small piece of metal welded in the middle and just bolt the bumper to it.
Look is a personal preference, don't let people on here get to you for doing a bumper swap. I've always liked the eclipse rear end more than the talon.
*edit in* better yet no welding needed. Just get a bit of metal you can bolt onto the rear, and then to the bumper. You will need to take the rear bumper off if your gona do the bracket method, and let me tell you.... It's gone be rough if you got big hands. if you take the rear off, look for some way to support the bottom of the bumper as well or it will always seem a bit loose.
I did the zipties because I've been out of a job with no money for 3 months.
Yea I fixed it today bought L brackets to pull it up. Never thought about zip ties would been whole lot easier today LOL.
  • Wanted 6 bolt NT water pipe
    • chrisman287
