95 or ross pistons???
streetraceboi
Moderator
828
369
Sep 4, 2002
San Antonio, Texas
heres the deal. i took apart my 91 tsi awd apart because of smoking issues. turns out i cracked three of my pistons. so what i wanted to do was to put 2g pistons on 1g rods. but a friend said i wont be able to because the cylinder walls have damage and i have to get them bored .020 over. do i have to bore them out or can i hone them?? a friend said i wont be able to install the 2g piston when i bore the walls out because they wont fit, is this true?? i thought it was the rings that sit the pistons?? can i use the 2g pistons if i bore it .020 over?? he said hell sell me ross pistons installed on the rods for $100, but he only has three. he said he can get the other for 50 bux. hes going to also sell me 95 pistons for $50 bux. which ever i want. the ross only have about 1000 miles on them. what should i do??? how much will the machining cost?? please help:confused:
if you had wall damage and just honed it out you would still have scares in the walls most likely. so you need to bore it .20 over and no the stock pistons will not fit you will have to get pistons that are for a .20 over bore.
if you are going to the trouble why take a chance just do it right. and then you wont have to worry about the rings trying to set in a damaged cylinder.
unless you want a different compression, i dont see why you would not just get oem pistons.
