95 eclipse won't stay running
Stewy3035
Sep 28, 2013
Evansville, Indiana
I have a 95 eclipse rs that won't stay running. Sometimes it'll start and rev to 3 or 4000 and die after a few seconds or I'll have to give a little throttle to get it to start and then it'll rev up and die. It has a new ecu,fuel pump,asd relay,coil pack,and tps. I've tried everything and can't figure this problem out. It give code 36 with the key dance. Any help would be appreciated.
I've already replaced the crank sensor, but not the cam sensor. Would that make the car rev high and die?
usually if a CAS is bad you wont get spark at all or at least not to all cylinders but it could because of it reading bad timing. it sounds like it has to do with ecu not reading correct air fuel ratio(MAP sensor) or a possible timing issue(CAS)
You may want to check fuel pressure regulator as well
