91 tsi coolant temp gauge
GettinPaper
289
Aug 31, 2009
Battle Ground, Washington
Hi, i'm a nubcake.
and i'm wondering why the hell my coolant temp gauge isn't working?
Sometimes it'll skyrocket into the red then just go ecstatic.. and now it doesn't even work atm.. i also just replaced the thermostat..
The one next to the temp sensor is the guage sending unit. That is what sounds like is disconnected and that would be why your temp guage does not work. The brown wire should be fixed as well. You can just cut the stock plug off and use female spade crimp on connectors like I did for both sensors if they are not able to be repaired otherwise.
well i fixed the wiring to the coolant temp sensor but now where does the wire to the other one go to?? LOL.. >.<
  • Wanted 6 bolt NT water pipe
    • chrisman287
