90-94 vs 97-99 motor identification
paranoidTSi
1,608
Dec 27, 2002
none, Utah
As mentioned before I recently discovered that my 95 talon does NOT have the orig. motor in it based on the fact the crank angle sensor is on the side of the valve cover. I understand that 95-96 cars did not have this, and I verified this through my friends 95 talon which had no CAS located on the side of the valve cover.
Now my question is, how can I tell what motor this is since both 90 to 94 motors had it on the side as well as the 97-99s? I assume it is a 97 - 99 motor since a 1G motor drop-in would require a little work correct? Any help appreciated. :talon:
