75mm TB bolt on check it out
Looks like another crappy chinese product that has no warranty and leaves you screwed out of $300 for something that's prone to failure. Read the "warranty" information. You can't install it for them to cover their warranty. Why the hell would I buy something like that?
All new parts come with 30 days warranty (Valid 7 days after products shipped)
Buyers are responsible for all shipping fee (include all return shipping fee). Shipping fees are not refundable.
Product must be returned for refund.
A returned product must be in the brand new condition, must never be installed, must come with all parts. Attempting to repair the product will void the warranty. Misuse will also void the warranty.
Refund minus 25% restocking fee
Buyer must contact me before returning the products
No refund or return for buying wrong product, not fit or change mine.
I don't see it as hassel free for a stock set up has it does not have a place for the throttle switch which is important for a 1G and more so for a 1G auto.
I see you have a 2g not sure you have one of them .
It says it has a place for the IAC not sure if they mean idle speed motor or the tempature fast idle controler but cant see a spot in the pics for eather of them . And besides if you look at the pic the part on top is realy the bottom as it mount the other way on the manny and there is no place for the isc as it goes on the bottom .
And the inlet wont hook up to any stock UIC pipe also .And dont see any of the ports for the vac lines . I'am not sure the add is 100% correct .:nono:
(I think it's a EBAY thing )
Just my obsevation and 2cents .
But for a race only motor it looks ok, be nice if it said what the shaft size and butterfly thickness is to see if it would hold up to high boost and all .
Maybe some one that has one will post about it .
Yes I do have a 2g. And yes I have a race motor. I'm using 3" intercooler piping. Thats probably not the actual picture. I figured this would be easier to hookup than the other 75mm tb. I guess i'll just use the magnus tb which I already have.
How would this bolt up? If it carries 75mm all the way through then it would get into the bolt holes on a stock manifold. If it doesn't get to the bolt holes then you would still have to hog out your manifold. And for what its worth I bought my 5.0 Professional Products 75mm throttle body for $50 slightly used. That looks like a rip off.
Yea figured you had race motor just wanted every one else to see what you get vers what they claim .I'am like you in that the pic of it does not fit the desciption to well . Good luck on your engine :thumb:
