75 amp alternator or 90 amp?
Lionel Hutz
48
Oct 31, 2004
Mississauga,
Is it a bad idea to use a mitsu 75 amp alternator instead of a stock 90amp one? I don't have any aftermarket stereo or accessories.
well, if it needs a 90 amp alternator and you put a 75 amp alternator in instead, then you will be starving the electrically componets and that's not good. I would just put a 90 amp alternator back in
speedy_talon28 said:
well, if it needs a 90 amp alternator and you put a 75 amp alternator in instead, then you will be starving the electrically componets and that's not good. I would put just put a 90 amp alternator back in (but, that's my .02)
I probably would too.
  • Wanted 6 bolt NT water pipe
    • chrisman287
