6 Bolt Swap Questions (allready searched)
805eclipse
159
Jul 16, 2003
Newbury Park, California
From spending several hours on the forum searching i have not seen an answer to these questions... I am planning on buying a full 6 bolt engine with turbo and all to drop into my 96 eclipse..
1.) Will i be able to use the 14b that comes with the engine or will i have to use my turbo and exhaust manifold from my 2g???
2.) Will the stock intercooler pipes bolt up to the 1G Throttle Body?
3.) When using the 6 bolt block and 1G head with 1G CAS is there still the issue of Random Missfire CEL, and having to switch injectors or plugs around?
I know theres tons of threads on here about 6 bolt swaps but i didnt really get this info from them.. THANKS.
Use the turbo/mani from the 2g. You will have to get an "install kit" which consists of a few things such as oil line, bolts, gaskets, and a "j" pipe. If you have the means of a few hundred bucks, upgrade your turbo.
Your planning on using the 1g TB and neck? Or taking if off of the 2g? It will bolt up either way you do it.
I have yet to experience any CEL with my swap. Doesn't mean it won't happen. The only plugs you will mess with are the 2g crank angle into the 1g cam sensor. :)
i am gonna use the 1g TB and the neck from the 1G so that will work with the 2g UICP?
