5-wire Earthing/grounding kit - what to connect to?
soldave
737
Feb 17, 2008
Okinawa, Japan, Asia
Well I've just managed to pick up a HKS earthing/grounding kit from some guy here for $20. It's HKS which means I'll automatically make 20bhp out of my car ;). Anyway, the thing has only come with 5 wires. Now I've read the thread at http://www.dsmtuners.com/forums/art...5889-homemade-4-gauge-grounding-wire-kit.html about making a grounding kit and I see the 8 places that it should connect to. Will the kit still work with 5 grounding points connected or do I really need the other 3? If so then I'll try and get some more cable so I can connect it all up.
If 5 points will be ok, which are the 4 ones I should connect to as well as the main battery ground? Also, my battery has been relocated to the trunk so if you have any advice about that situation, it would be appreciated :)
  • Wanted 6 bolt NT water pipe
    • chrisman287
