4wd abs fuse?
red eclipse gsx
109
3
Jan 18, 2004
Chalfont, Pennsylvania
Hey, I was roaming around in my fuse box in the engine bay, and I noticed that I didn't have a fuse (15amp) in the 4wd ABS slot. I have a 2g 1999 Eclipse GSX. Is there a benefit to not having a fuse here, for racing purposes, or did my shop mess something up. :confused:
So we know that it does not matter if its an AWD Auto or Manual with or without the LSD...
None seem to have it.
well it wouldent be there for 4wd ABS labeled and everything.... but with no leads to even put a fuze in if no one had it.. someone has to have it or know what it does.... there are 2 ABS fuses but only one is 4WD.... so no if u dont have an AWD.... its obvious you wouldent have the 4WD ABS lead or even the indication that there was this fuze.... but since i do have AWD.... and ABS... im curious as to why this one is missing still...
Well look at your gauge cluster sometime. There are a shot ton of unused dummy lights in there.
Mine has Awd, auto, abs, and LSD rear... It doesn't either, so your not special.... That's the point of the thread.
Honestly if your car is ABS and you have tested the system and it is working. These boxes are casted identical no matter what gsx it's going in. If your car seems to be working and the ABS is engaging and the car is running normally I would take no serious concern to the issue. It may just be a different option, or vehicle manufacturing date thing.
woooosh
The issue is where the ABS ECU gets its power on the cars that don't have a low-amp fuse (nor the wiring); we know his ABS is working.
I haven't had a 2G for several years, so this is coming from a memory system that lived through the 1970s, but I want to say that it gets it from the cabin fuse, just like the main ECU, on the later-year cars.
