4g63 exhaust mainfold help????
hydeco tsi
Mar 23, 2011
scranton, North Carolina
i have a 98 eagle talon tsi with the evo 3 16g on it and i need to replace my gasket....its leakin.....when i try to get the bolt off from the bottom passenger side a line is in the way...i think its a cooling line from th turbo its metal and i can move it..... does anyone know how to get the manifold off??? do i have to drop the turbo and all just to change the gasket and what are the best gaskets to use on the exhaust manifold thanks if you need pics i can post some if it help you all figure out what i need to do thanks>>>>>
If I remember right, the line is for your oil feed. just pull the line and replace the crush washers. You can leave the turbo in the car and just pull the manifold off. Id recommend a Copper gasket.
the line is metal and i cant move it the nut hits the line and i cant get the nut off to take off the manifold...
its either the oil feed line or water return line. the oil feed you undo from the head and move out of the way. the water line has a rubber portion that you undo and then are able to free the manifold
