gamble9465
- 0
- Feb 17, 2009
Myrtle Beach,
South Carolina
i have a 1994 4G63 complete block and trans. i pulled it out of a running eclipse to build. i Install stage to HKS camshafts, 264 intake, 272 exhaust. High flow adjustable fuel rail made by VENOM, RC 450cc injectors, custom painted valve cover and intake manifold. new valve seals HKS header, ever seal is new and replace right all work to motor was done by jordans performance in Myrtle Beach Conway. the head as been port match to header and intake.
block as new main bearings , new rod bearings new piston rings, new wrist pins new forged pistons. block was decked and check for level and was perfect so no wrapage. new timing belt, new water pump new oil pump. have a documents about every part bought and put in the motor. and how much jordans charged me. I have over 1100 in the motor. the transmission is a 5SPD hydro clutch. i would like to get 700 from complete with axles, wiring harness, ecu, trans motor. you can contact me @ xxx xxx xxxx Mason
