2G 420a Can't Figure Out What's Wrong...Idle Drops Close To 0 When Coming To Stop...
EagleTalon24
129
Jan 1, 2010
Seattle, Washington
It all started with exhaust popping on idle. In park the idle stays fine but once I start driving and come to a stop the idle will change up and down and will be on the verge of 0 but will resist stalling. When driving freeway speeds the idle does not surge or fluctuate only when coming to a stop.
I have cleaned my throttle body. I've checked and gapped spark plugs, wires, ignition coil. The car has a new fuel pump as well and am getting 45 psi fuel pressure. I also installed a new fuel filter.
I've checked my MAP sensor, and replaced my air intake temperature sensor because my check in engine light showed that, now it went away.
Engine Compression is 120-130 on each cylinder.
I am not sure what can be causing this sputtering? I can't seem to figure it out...
Is that normal for a 420? My current 420 is the first one I've had since 2005, and I never got into much mechanically with that one, and so far only have transmission issues with the current one, although I have way more knowledge and tools than the last time, so I'm prepared now.
