Resolved 420A alternator belt adjustment
dsmrydah
Dec 19, 2004
Baltimore, Maryland
does anyone have a diagram that clearly pictures how the belt is installed. And also what brackets and bolt would be needed i have a 2 g nt. any sites i can refer to???
wret said:
Are you trying to replace it or adjust it?
There is a bracket that when i got the car some dumb ass didnt put on so. i just have the loct nut now and not the adjuster. but what i did was manually adjusted it with a crow bar and tighted the screw it seemed to be holding well but i still wana get that bracket. i took it for a test run and the battery light never came on so it might be cool. :thumb: :thumb: :thumb: :rocks: :rocks: :rocks: :thumb: :thumb:
does anyone have a pic of this where it is located. i cant tighten my belt and from the searches this must be my problem. where can i locate one, can i make one, or if anyone has a belt size as to bypass it altogether :mad:
thanx
The bolt is on the top bracket that the alt is on. The bracket is right underneath the IM. If no body posts a pic by tomorrow, i'll take one before I come to work (I work 2nd shift).
yea that would be helpful. thanx in advance i have the bottom bolt and the lock bolt thats it. from the searches i must of lost the tensioner screw/bolt what is the part number for this bolt? seems like a common prob to lose it
