TalonSpeed
- 526
- 21
- Dec 22, 2002
Little Rock,
Arkansas
I came across some very rare 03-05 Nissan 350Z track wheels. They are forge aluminum. With these specs:
Track 18" v.1
Extremely lightweight and stylish, the Rays forged Track model wheels have been a desirable upgrade for owners of other models.
Front
Offset: +30mm
Weight: 18.19lbs
Tire: 225/45/18
Rear
Offset: +33mm
Weight: 18.62lbs
Tire: 245/45/18
I plan on running 245/40/18 on all four corners. Or maybe 255/40/18 although I doubt they fit with these offsets. I plan on putting these on my 2G 98 AWD Talon, lowered on ProKit springs and AGX shocks, with 5 washer rear camber kit.
Im sure the fronts will fit. Not sure about the rear, but according to this thread ( http://www.dsmtuners.com/threads/350z-wheels-on-a-2g-explained.343588/ ) they will fit with 1mm taken off the wheel hub bore. At 18lbs for a 18" rim for less than $300 with tires........deal is too good to pass up. What you guys think?
Track 18" v.1
Front
Offset: +30mm
Weight: 18.19lbs
Tire: 225/45/18
Rear
Offset: +33mm
Weight: 18.62lbs
Tire: 245/45/18
