300zx wheels on a 92 GSX
mygsx2120
353
Jan 4, 2006
Newark, Ohio
I have did some research and know that I can use NA 300zx rims on a 92 GSX. I want to make sure I understand everything correctly. The centerbore part I fully understand, so no need to go there. They are 16x7.5, with a 45mm offset. The VFAQ said that spacers were required. So onto questions,
I don't want to go bigger than a 5mm spacer, is that big enough? And if so, what tire size is correct. 235/40 too big? Is a 225 to small for a 7.5inch rim? I'm not one for stretched tires. Thanks in advance
P,S. First post in years. My roommate has the 1g GSX, and my best friend just recently acquired a VR4. Feels good to have a reason to be back
  • Wanted 6 bolt NT water pipe
    • chrisman287
