3 OEM PCV Valves failed...What next?
Sleezy_E
Aug 25, 2005
Lancaster, California
Just like the title says, my boost leak has been caused by a leaking PCV valve. So I bought 3 more from the dealer and all of them leak during the boost leak test. I researched and saw that this is very common, even with OEM from the dealerships. Some people just replace the valve with a straight fitting, but I don't understand how that fixes the problem cause it has to ventilate the crankcase and seal up under boost. Any ideas?
The guys who replace it with a straight fitting also cap the fitting on the manifold so you don't wind up with a major boost leak into the crankcase.
Make sure you take the OEM parts back to the dealership and show then how they are failing.
Steve
