2gmas on 1g, upper intercooler pipe doesn't fit?
dmxsoulja3
71
Sep 4, 2004
Gulf Breeze/Pensacola, Florida
Ok so I just swapped in the 2g mas and Dejon intake on my 1g and the stock upper intercooler pipe doesn't fit, nor does my aftermarket pipe I have, I'm wondering if the 2g upper intercooler pipe would work or if the engine bay is radically different,. or if you guys had any suggestions or have done this swap.
Josh
:talon:
Are you using an intake pipe for a 2g or a 1g? I have the Dejon 1g intake with a 2g mas and it cleared my stock ic pipes as well as my aftermarket ic pipes (short route).
Josh I have a Dejon upper IC pipe that takes the GM MAF. I have to say it takes some muscle to get it onto the IC nipple as it appears to be "half a nipple short". i dread the couple times I had to take it off but once it's on it stays there. Mark
I have a 2G mas on my car. You have to get a 2G mas to 1G intake to make it fit. My Buschur UICP fits thru the FIPK with the intake but it takes some pushing on the filter.
