2G Total Teardown and Rewire
Silver vein looks good, I had all my stuff done in red vein. Good luck with your project.
Current project :
We are getting the Dynatek ARC-2 installed, It's a nice part and really look forward to the improvement.
Took a break on the suspension work for a while, That's a nasty job, and I was just looking into the Magnus Chromoly rear subframe.. Awesome part.. 25 lbs lighter + a much, much better design. Gotta save weight any way you can and 25 lbs here and there add up...
KL-Motorsports Image Gallery - 2G DSM - Camera 2/Power Box prorgress
Power Box.. Alot more to do.. Hope you can all see the quality of this build.
Here is more progress on the power box...
KL-Motorsports Image Gallery - 2G DSM - Camera 2/Power box getting there..
Enjoy!
Anyone here have any direction experience with Dynatek CDI?
Also looking for opinions on the AEM Boost Solenoid
Thanks!
Well..
The project is still coming along.. tick tock
Were working on it.. But nothing huge as of yet
Just fine-tuning some wiring stuff
and more, and more, and more, and more powder coating / "detail work"
The bulk of the work includes
Getting the exhaust wrapped + installed
Getting intercooler repaired (fedex damage)
Getting parts installed on motor (such as intake manifold, sensors, throttle body)
Finish getting new bolts and powder coating of all the suspension parts and getting the Poly bushings installed
Getting the rear chassis wiring sorted out
Getting a few new mitsu parts installed (headlights, front axles)
Get the CDI Mounted and Installed (no more ignitor with the AEM)
Get TriggerDisc installed
Wire in gauge cluster setup, Get new LED bulbs
Fabricate a plate over the HVAC area for switch-plate
-misc powdercoating of interior brakcets, door parts, seat rails, etc-
Check it over and over again, Fine-tune the mounting and routing of wiring, AEM, CDI
It just goes on, and on, and on, and on
Nice to meet some people at the meet, gallery has some updates
Check it out
After taking a break, Were getting back into the project now..
Looking for suggestions on Weight Reduction.. Im sure we got alot of it covered already... but were looking for things like Magnus Rear Subframe (which we have) thats 25 lbs lighter + much stronger.
Trying to get this thing down as light as possible, all the ABS stuff is removed, the little wheel sensors and all that.. so anything un-needed in the car needs to go, just looking for suggestions on things you have done and / or seen done
