2G Talon AWD Auto Part Out
OneBad2L
145
3
May 20, 2009
Saranac, New York
All prices listed are best offer and shipped. Will ship Priority, First Class, or UPS Ground depending on item and weight. Local pick up would be great and is needed for the shell. May deliver shell or trans for the right price and paid deposit in advance.
2g Auto Transmission out of a '98 GSX 84k miles. Great Shape. Trans Torque Converter Sensors and Mounts - $550 shipped
2g Auto Transfer Case out of a '98 GSX 84k miles. - $175 shipped
2g Auto LSD 4 bolt Rear Diff out of a '98 GSX 84k miles - $300 shipped
2g Auto LSD Rear Axle (Pair) out of a '98 GSX 84k miles - $200 shipped
2g Auto Starter out of a '98 GSX 84k miles. - $40 shipped
2g Auto Starter plate out of a '98 GSX - $25 shipped
2g Auto Shift Lever, pedals, and cable, out of a '98 GSX - $sold
EVO 8 Enkei Rims with Dunlop Direzza Star Spec Tires. 235/45's. Tires were $650 alone and have under 5k miles - $725 shipped
1g 6 Bolt Stock Cylinder Head with stock springs, cams, and cam gears. Surface looks great. Fine to run as is with a composite gasket or use to upgrade - $175 shipped
1g Stock Intake Manifold - $35 shipped
1g Magnus V3 Cast Aluminum Intake Manifold. New in box. Powder coated black. 90mm 5.0L Mustang flange includes stock 1g throttle body adapter and Magnus heat barrier gaskets for intake and throttle body. Paid $1100. - $sold
2G 1995 Eagle Talon AWD rolling shell. 89k miles. No motor, trans, rear diff, or axles. Everything else is included, see below. - $1000 b/o
Has full drive shaft, new gr2 front struts, new oem front knuckles and control arms on both sides, rewired walbro 255, 30psi boost gauge and dual gauge pod, 3" turbo back exhaust, '98 Eclipse front bumper and headlights, stock Talon twisty skirts, rear bumper and spoiler, stock radiator and fan, alternator, fuse box, 2g maf, all sensors, wires, hoses, and full manual wire harness with a 1g in 2g cas adapter. Everything above is bolted in and or connected.
Car is the stock Wildberry Pearl color, was repainted in 2006 but two toned with a very deep metallic purple on the top half (hood roof and hatch). The purple looks black from every angle until you are up close. The body is in great shape, no dents, no strut tower rust, no body rust, and the undercarriage is clean too. There's a few minor scratches around and webbing/chipping paint on lower front bumper from bottoming on driveways. Interior is nice and very clean but the headliner is coming loose. Car has that rumored new car smell that is said to linger in some of these without an air freshener in it. Never smoked in while I've owned it.
It has it's own corner in the garage and gets stored and covered every winter. Needs a good home with an owner that will take care of it. Will include any parts still available in the ad above for a reduced price. (full auto swap 6bolt head intake etc). $1000 b/o
Calls between 3-6pm eastern are okay. Text any time day or night. 518 Five78 6969
Steve.
DSM Classifieds - Download:
