Resolved 2G Sudden jerking
Cynxe
263
6
Feb 19, 2015
Ottumwa, Iowa
I put my car in 1st, and started to drive when my car suddenly jerked and bucked me as if it hit fuel cut, all my dash lights came on and the dinging noise as if I was turning my car on. And it stayed started. I had just changed idle air control and removed positive terminal, but I had made sure everything was good and tight after the first jerk.
I started driving again and did a couple pulls to make sure, but when I pressed in the clutch and started braking hard it did it again but without the jerk, as I wasn't giving gas. But this time stayed off. Then it did it on a turn and I can hear loud clicks coming from my ECU area.
It would start but then wouldn't stay started. So I popped the hood and it smelled like burning plastic. Or electrical. I popped the fuse box and some fuses were hot. But I got back in and it started up and I drove it home easy.
I have no idea whats wrong, I hope someone else had this problem.
Sounds like you have a bad wire or loose connection somwhere. Make sure your battery terminals are actually getting tight. Could be your battery might want to check output of that and alternator. Also check MPI or Engine fuse make sure it's not blown or about to blow.
Sounds like you have a bad wire or loose connection somewhere. Make sure your battery terminals are actually getting tight. Could be your battery might want to check output of that and alternator. Also check MPI or Engine fuse make sure it's not blown or about to blow.
I know alternator is good
Why does it do that? Like it completely stops the car but none of the lights turn off
Make sure your battery isn't shorting against the hood. If you just moved terminals this is suspect.
So holes in the hood?
OMG, you're literally the best, I seriously don't know what I'd do without you man.
