255 Fuel pump installation kit?
amballer82822
361
4
Jun 4, 2010
Pittsburgh, Pennsylvania
Hey guys I own a 98 GSX and just put in few mods bigger turbo now time for bigger pump. I loosened everythings and took off fuel lines now I can pull the pump, I just bought the 255 walbro itself no install kit, do I need an install kit or can I just use original parts? All I have is the pump itself
No, you will need the kit.
The oring is a differant size vs the stock one. WIthout it, it will not hold pressure.
I ended up using a peice of hose and come clamps. I used the proper install kit for it. After a few months it leaked pressure.
The walbro also uses a slightly different sock than the stock one. A different plug, a different bottom rubber isolator, and as stated the o ring, the walbro also has a little plastic piece that goes on the end of the pump outlet.
