How does a boost gauge work?
nbnguy98
May 1, 2004
Herndon, Virginia
Does anyone know? So it's tapped into the vaccuum line. When the engine is off, it goes to zero. But when the engine is running it actually goes negative (like a vaccuum). Not only that. it's measured in "inches of Mercury". Then when I start boosting it goes positive, gets to 0 and then peaks to about 12 PSI (which is a different unit of measure). So the question is why two different measurement of pressure? and why does it start in the negatives, passes 0 and then finally goes positive? Read the forms, it does seem that the stock turbo gets about 12 PSI, so I assume it's reading correctly.
PSI = Pounds per square inch. That is a standard issue of measurement for any pressure gauge that uses SAE (standard american english) measurements.
in/hg (inches of mercury) = The standard issue of measurement for vacum gauges. This refers to the air pressure below ambient pressure.
Both measurements are levels relative to atmospheric pressure, so when the gauge reads 15 psi, the air pressure inside of the manifold is 15 psi above atmospheric levels. When it reads 15 in/hg, then it's reading 15 inches of mercury below ambient air pressure.
    Three speed design 1g scatter shields. Stainless steel. Have half a dozen 1g Fwd. ($95) two...
  • Wanted 2g 2g Automatic transmission mount part # MB911274
    With A/T in the casting on the mount. Autos have 3 bolts holes, manuals have 4 mounting holes.
    • bduran1220
  • For sale Part Out: 1992 Laser AWD
    This is a 6 bolt/4bolt DSM. The engine and transmission are currently not for sale as I am...
    • OMN_DSM
  • For sale 2g 95-98 Talon air bag.
    2g Talon airbag. Really good condition. Can ship ups ground. Apparently illegal to list for...
  • For sale 2g 95-99 4g63 TCU
    Came out of my 95 Talon that was manual swapped. $70+shipping. My eBay is “scoot_martin” if...
    • the-dsm-goblin
