20g o2 housing
blowinsmoke95
112
Oct 24, 2009
Roundtown, Ohio
kay guys... ive installed a 20g on my 2gb eclipse... i need an o2 housing for it,.. where can i find one?? or a downpipe that eliminates the o2 housing... i just need something so i can drive the car.... thanks in advance...:dsm:
The only way the 02 housing would not fit is if it is a t3 tubo with a 5 bolt downpipe flange if it bols up to ## stock header than the 02 housing should bolt up to ## tubo too the stock 02 housing bolts up to 14b 16g 18g and 20g turbos if it share the same header flange
it wont bolt i tried several times and i had to buy a new manifold t3 flange and it has a mitsu sign stamped in the turbo so idk but it will not work even the ebay 20g comes with a diff o2 housing and all that stuff they just wont sell the o2 housing seperate
and a t3 flange wont bolt either i have one
the turbo i have is supposed to be a 20g it has a 3 bolt o2 housing flange i know it is a stock turbo off a mitsu cause it has a mitsu sign stamped on it but it is like an inch and a quarter bigger than my stock t25 i dont get it
