Resolved 1g tb stop needed for 2g?
Solution
Is the 1g throttle stop nessesary while running a 1g tb in a 2g car?
The "throttle stop" on a 1G is actually the idle position switch (IPS). It tells the ECU when the throttle is closed. It is needed on any 1G throttle body to set the blade to the correct opening off throttle. So yes, it is 100% necessary. You could replace it with a bolt, but it still needs to be set correctly.
Whether or not it needs to be wired up depends on what TPS you are using.
Solution
I chose to use the switch off the 1g as the stop because I couldn't find a bolt thats the right thread pitch and I didn't want to tap it for some ugly construction bolt.
  • For sale 4G63 Race parts.
    It is the time to make room to improve the DSM, getting rid of some extra parts I no longer...
    • GST2012GSX
  • For sale 1g 1g turbo oil feeds
    1g TD05 oil feeds. Found another box. Have 15 feeds. Have no return lines left. Been running...
  • For sale 2g 29 tooth auto speedo
    29 tooth 2g auto speedo. Good condition. Price is shipped. Message 702-741-6987
  • For sale 4G63 91 to 96 Auto T Case
    91 to 96 Auto T Case $195 + shipping & paypal feesYou must be registered to see element.You...
