dsm'r sk1mp
- 342
- 1
- Aug 8, 2009
post falls,
Idaho
It is a 94 mitsu eclipse gsx. Mods include aluminum radiator, tubular manifold, and 255 walbro. It has a hundai head, everything else is stock. It also has a blitz turbo timer but i highly doubt that is causing the problem. The problem is its losing power after it warms up. Here is the twist that is bothering me. Once it has warmed up there is a sudden drop in tempature and a loss of power. Loss of power as in, it acts like its bogging down and flooding almost. It has great compression(155 all across) and it runs great while warming up. We replaced the temature sensor, cold start sensor and adjusted the CAS. Keep in mind it does have extremely minor shaft play, and a good chance of bad turbo seals. Im tempted to say the thermastat is bad but it opens and closes perfectly fine. any ideas?
I had this same problemnot the drop in temp but the bogging) i thought it was my ecu as well, but i had it checked, socketed and got dsm link. The problem was a Boost leak in one of my injector seals. Save some time and money and do a quick boost leak test. i use soap and water around areas that usally leaks helps find it faster. hope this helps. for the loss of power part anywho.
