1G 1G fuse box relocation and wire tuck
Take all the bolts off holding this piece of plastic on their should be 3 or 4 bolts. Carefully unclip all the sensors in the area after (4 fuel injectors - cam angle sensor - TPS - coil pack - transistor -thermostat housing (3) sensors be careful on these cause they are brittle also the ISC - O2 sensor - throttle plate sensor (remove the fuel rail bolts 1 by 1 to remove the cruise control cable and get it out of you way its a pain in the ass, l tuck it back out of the way.
Here's the wire bracket off. Take our flat head and pry out on the tabs careful in case you want to use this piece again.
Here's the firewall the harness runs along the wall with bolt brackets you can remove with zip ties holding them to it. Trace it all the way down to the end (brake and clutch (manual) fluid resv.) Make sure you also unplug the fuel pump box plug - cruise control plug - unbolt all the ground wires from the fire wall, their should be a few - Noise condenser resistor - (i will try and get some pictures of these sensors.
Don't forget to unplug this sensor if you have a manual transmission its tucked away.
Here is the bracket remove this (2 bolts) it will make life a lot easier.
Take and do this with your wires and start to strip all the hard wiring stock sleeves that are stiff and ZIP TIE your wires together and rap some new WIRE LOOM around them or what ever you choose - its a lot easier to remove all the stock shit cause it allows you to bend and move the wires 100% better, plus its cleaner.
Here's how i did it.
After you get all the wires over the side stripped and re-loomed etc. trace the harness along the side to the fuse box. You are going to need to cut some of the zip ties hold it down to the frame. Unravel some of the stock wrap on the wire and expose them like so.
Cut and splice the wires and number them accordingly. i suggest soldering them one at a time so you don't get confused.. that's what i did..
This is the main harness remove this connection to get the other half out that connects to the starter.
This is the starter harness remove this and disconnect the bolts on the starter to remove the rest of it also bolted to the fire wall.
  • For sale 4G63 6 Bolt ARP Head Studs
    ARP 6 Bolt ARP Head Studs $65 + shipping & paypal fees* these have been torqued onceYou must...
  • Wanted 2ga side markers
    Looking for 2ga side markers
    • Rohitter7878
  • For sale 2g 2G Fwd Thermal Research exhaust
    2g Fwd Thermal Research cat back exhaust
    • ari2gdsm
  • For sale Used Tial 44mm wastegate
    Looking to sell my used Tial 44mm wastegate. Legit Tial gate, verified by Tial. Can send...
    • Anfurnyy
